309
预喷射在主喷射之前,将小部分燃油喷入气缸,在缸内发生预混合或者部分燃烧,缩短主喷射的着火。这样缸内压力升高率和峰值压力都会下降,发动机工作比较缓和,同时缸内温度降低使得NOx排放减小。预喷射还可以降低失火的可能性,高压共轨系统的冷起动性能。
主喷射初期降低喷射速率,也可以减少着火期内喷入气缸内的油量。提高主喷射中期的喷射速率,可以缩短喷射时间从而缩短缓燃期,使燃烧在发动机更有效的曲轴转角范围内完成,提高输出功率,减少燃油消耗,降低碳烟排放。主喷射末期快速断油可以减少不完全燃烧的燃油,降低烟度和碳氢排放。
柴油共轨系统已开发了3代,它有着的技术潜力。共轨高压泵总是保持在压力,导致能量的浪费和的燃油温度。第二代可根据发动机需求而改变输出压力,并具有预喷射和后喷射功能。预喷射降低了发动机噪音:在主喷射之前百万分之一秒内少量的燃油被喷进了气缸压燃,预加热燃烧室。预热后的气缸使主喷射后的压燃更加容易,缸内的压力和温度不再是突然地增加,有利于降低燃烧噪音。在膨胀过程中进行后喷射,产生二次燃烧,将缸内温度增加200~250℃,降低了排气中的碳氢化合物。
由于其的技术潜力,今天各制造商已经把目光定在了共轨系统第3代—压电式(piezo)共轨系统,压电执行器代替了电磁阀,于是得到了更加的喷射控制。没有了回油管,在结构上更简单。压力从200~2000巴弹性调节。喷射量可控制在0.5mm3,减小了烟度和NOX的排放。
Le invitamos cordialmente a visitarnos en nuestro stand HALL 38-156. Lo invitamos a aprovechar la oportunidad para establecer nuevas relaciones comerciales y consolidar las existentes.
Esperamos darle la bienvenida en nuestro stand, donde mostraremos nuestra amplia gama de servicios y soluciones de inyección de combustible.
Dear exhibitors, visitors and partners:
The leading event for the automotive industry in Asia - Automechanika Shanghai is back early in 2023, We hereby sincerely invite you and your company representatives to visit our booth 4H26.A3 in Hall 4 at The Automechanika Shanghai 2023 – Shenzhen Edition from 15 to 18 February 2023. The 17th edition will take place at the centre of China’s innovation capital in the Shenzhen World Exhibition & Convention Center, We’ll be demonstrating our new Fuel System Parts at Automechanika Shenzhen Edition 2023. If you’ve been looking for solutions to Diesel Solutions, you’ll want to make time for this!
Automechanika Shanghai is one of the most influential global trade fairs in the automotive industry, offering an arena for marketing, trade, and networking. So see you at the show? We hope you will get benefit from this trade show. It would be an honor for us to your company’s participation.
The leading event for the automotive industry in Asia - Automechanika Shanghai is back early in 2023, Industry leaders head to Shenzhen as doors open for the special edition of Automechanika Shanghai, The trade fair, assembling 3,302 exhibitors across 220,000 sqm, will meet the industry’s call for in-person business encounters between Chinese and overseas companies. Automechanika Shenzhen PODGK po@china-lutong.net Edition concentrate on 4 key aspects of the automotive market - aftermarket, electric vehicles, connected cars and e-commerce. Automechanika Shanghai 2023 gathers world-renowned industry leaders across the entire automotive ecosystem and serves as a dedicated platform for professionals to connect at one of Asia’s most influential automotive trade fairs. The fair covers the entire supply chain and offers a strong collection of products, services, and technologies that meet the current and future needs of the market.
“电控”是指喷油系统由电脑控制, ECU(俗称电脑)对每个喷油嘴的喷油量、喷油时刻进行控制,能使柴油机的燃油经济性和动力性达到的平衡,而传统的柴油机则是由机械控制,控制精度无法得以保障。
“高压”是指喷油系统压力比传统柴油机要高出3倍,能达到200MPa(而传统柴油机喷油压力在60—70 MPa),压力大雾化好燃烧充分,从而提高了动力性,达到省油的目的。
“共轨”是通过公共供油管同时供给各个喷油嘴,喷油量经过ECU的计算,同时向各个喷油嘴提供同样质量、同样压力的燃油,使发动机运转更加平顺,从而优化柴油机综合性能。而传统柴油发动机由各缸各自喷油,喷油量和压力不一致,运转不均匀,造成燃烧不平稳,噪音大,油耗高。
